Microlight Question
bean_ian
Microlight Question
Post by bean_ian » Thu Aug 17, 2006 1:54 pm
I have been trying to gather information about the costs of Microlight ownership but i havent been able to find much.
Would anyone here know the cost associated with owning a microlight(say an X-Air). Eg, fuel, maintainence, annuals, initial cost etc...?
Nanolight
Post by Nanolight » Thu Aug 17, 2006 10:10 pm
Kevin Glynn might be yer man!
There's another gentleman here who flies a thruster... cant remember who it is though.
Smoke me a kipper, I'll be back for breakfast.
jonkil
Post by jonkil » Fri Aug 18, 2006 9:34 am
Having flown an X-air for about a year and accumulated 100 hours on it before I sold it, It is a 582 powered model, the costs are roughly as follows:
Fuel burn is roughly 16 to 18 litres p/h = ?20.00 p/h
2 Stroke oil (semi-syn Shell) =?5.00 p/h
Allow a fund for servicing/maintenance =?2.50 p/h
Associated on-going costs(permit e.t.c) =?1.00 p/h
Insurance required and mandotary =?12.00 p/h
SUB TOTAL ?40.50 per hour (assuming 50 hours per year)
This is probably a fairly conservative figure and has not assumed an engine rebuild at 300 hrs. (300 hours is a lot of flying), neither does it take into account buying the plane in the first place.
A good X-Air with an engine that is before mid term rebuild will cost between ?9000 to ?11000 Sterling.
Getting the pilots licence will cost ?3500 - ?6000.
If you dont have access to your own strip then hangerage will be additional on top of this.
Another route is to buy a share in an aircraft and for a fixed monthly cost + a per/hour fee you can have access to an aircraft. Problem here is that the aircraft may not be available when YOU want it!.
I have always assumed that a figure of ?80 - ?100 per hour is pretty realistic when you account for everything.
Hope this helps,
Jon
G-CCCT
Post by mark » Fri Aug 18, 2006 10:22 am
Hi bean_ian,
Take a look at the BMAA website at http://www.bmaa.org/classifiedlist.asp? ... vertPage=1 this will give you some information about the initial cost of a second hand microlight. Also take a look at www.xairireland.com for specific information about X-Air's.
www.flyinginireland.com
FlyingInIreland.com:- THE Resource for Irish Aviation Information
bean_ian
Post by bean_ian » Fri Aug 18, 2006 11:57 am
Cheers for the info guys, more or less exactly what i was looking for. Im in the process of getting my PPL(A) and im just exploring cheaper options once i have my PPL(A). I like the look of the X-Air, they look like lots of fun to fly
Is there anywhere in the country that sells trial lessons in X-Air's or something similar, just to see if i like it or rather stick to the Group A's!?
jonkil
Post by jonkil » Fri Aug 18, 2006 12:18 pm
bean_ian
e-mail me on jonkil@esatclear.ie and I will put you in touch with someone as close as possible to you.
It does not say where you are in your profile.
Jon
scraggane
Post by scraggane » Fri Aug 18, 2006 12:24 pm
does one require the PPL to fly a microlight? I was under the impression that this was not the case.
Flyer1
Post by Flyer1 » Fri Aug 18, 2006 12:28 pm
You most certainly do need a PPL. But it's a PPL (M). A microlight PPL.
bean_ian
Post by bean_ian » Fri Aug 18, 2006 12:33 pm
You can convert a PPL(A) to PPL(M) quite easily( 15 conversion i think...) but its alot harder to go the other way
seamus
Post by seamus » Fri Aug 18, 2006 12:52 pm
Private message me.
I own and fly a Thruster T300 from my private strip.
Shey
Post by mark » Fri Aug 18, 2006 12:56 pm
bean_ian,
It's only a 5 hour conversion to microlights once you have your PPL (A).I did it with Ultraflight at Abbeyshrule. It's just a 3 Axis Microlight Rating that's added to your licence.
Although i'm legally allowed to fly X-Air's and those kind of aircraft (I did my conversion on a Samba) I was told that the other types of aircraft are a bit trickier to fly and require a bit more training. The Samba is a simple aircraft to fly and provided you are reasonably current, you spend most of the time doing cross countries simply just to make up the five hours.
DonalMW
Post by DonalMW » Fri Aug 18, 2006 6:37 pm
S it is possible to convert an Irish PPL(M) into a PPL(A)?? Any1 know what's involved?? :?:
Nanolight
Post by Nanolight » Fri Aug 18, 2006 9:57 pm
I am totally open to correction on this (in case I get any facts and figures wrong :lol: )
*To fly a microlight you need a PPL (M)
*To get a PPL(M) you need 25 hours dual instruction, and 15 hours solo, plus cross country flights as with PPL(A)
*This entitles you to fly a microlight : fixed or flex, depending on which you trained on.
Now as far as I know, 15 of those 40 microlight hours count towards your PPL(A). You just need to do the cross countries again.
*PPL(A) syllabus requires that you do 5 hours instrument training, so you'll need to do that as it wont have been covered on (M)
The ground school is the same, and you'll have that done.
DonalMW
Post by DonalMW » Sun Aug 20, 2006 2:02 pm
Thanks nanolight! I'll definatly look into it, the extra seats would be nice for touring!!
CaptCream
Post by CaptCream » Thu Aug 24, 2006 2:37 pm
One thing to remember about a microlight for anyone thinking about going on to do an ATPL is that the hours do not count!! The Samba that Mark did his flying is a lovely aircraft and can be bought new for around ?73k as far as I remember, Mark can correct me if im wrong on the price. Mark covered all the details on how to get a microlight rating in the magazine a few months ago.
Users browsing this forum: No registered users and 14 guests
