Irish Airspace restrictions in place due state visits
trimflyingclub
Post by trimflyingclub » Wed May 04, 2011 10:45 pm
Due to the planned visits to Ireland by Queen Elizabeth II and President Obama, a number of temporary restricted areas (TRAs) will be necessary within the Dublin CTR/CTA, Shannon FIR and Cork CTR on various dates throughout the month of May. Details of all such TRAs will be promulgated by NOTAM and also, separately on this website. Pilots should check in advance for this information prior to undertaking any flights within the Dublin CTR, Shannon FIR and Cork CTR during May to ensure they do not infringe any of these TRAs.
...from the IAA website.
Any ideas yet what areas are affected, especially within the Shannon FIR? I don't see this anywhere else on the forum yet, if so, please move to correct location.
thanks.
TFC
Re: Irish Airspace restrictions in place due state visits
Post by hum » Thu May 05, 2011 9:26 am
The wording of this announcement is a little confusing since, as far as I am aware, the Shannon FIR includes both the surface areas that contain Dublin CTR/CTA and the Cork CTR.
sha fir.jpg (5.4 KiB) Viewed 3941 times
None of these NOTAMs have been published so far...when they are no doubt all will be clear...
StrikeCommand
Post by StrikeCommand » Thu May 05, 2011 9:45 pm
Does this mean Purple Airspace instead of Green Skies?
trimflyingclub
Post by trimflyingclub » Fri May 13, 2011 3:54 pm
Updates issued by the IAA today (13th).
http://www.iaa.ie/index.jsp?p=93&n=96&a=1054
FLIGHT RESTRICTIONS - Shannon FIR and Control Area, Dublin Control Area and Control Zone and the Cork Control Zone from the 17th to the 20th May 2011 inclusive.
Due to the planned visit to Ireland by Her Majesty Queen Elizabeth II, The Department for Justice and Equality for reasons related to security has requested the Minister for Transport to establish areas of temporary restricted airspace (TRAs) within which flight restrictions shall apply.
The controlling authority for all TRAs is the Controlling Officer of the Department of Justice and Equality.
A TRA will be in place 30 nm radius of Baldonnel Co. Dublin from the 17th of May continuously until the 20th of May.
A TRA will be in place 30 nm radius of the Curragh area Co. Kildare on the 19th of May only.
A TRA will be in place 30 nm radius of the Cashel area on the 20th of May only.
A TRA will be in place 30 nm radius of the Cork area on the 20th of May only.
ONE Low level Air Corridor TRA will be in place between the Cashel Area and the Cork area on the 20th of May only.
All scheduled commercial air transport aircraft, including charter and cargo operations in receipt of an Air Traffic Service which are departing and arriving at licensed aerodromes within the areas or transiting the TRAs under the control of an ATS Unit are not affected.
Non-scheduled commercial air transport aircraft and aerial work aircraft do require authorisation from the controlling officer of the Department of Justice and Equality (email co-flights2011@justice.ie) to include in the subject line the text "TRA Applications" (not case sensitive). If you do not include the text "TRA Applications" within the subject line-your request may be rejected. You will receive an automatic reply to your email application-THIS IS NOT AN APPROVAL. The appropriate approval if granted will be relayed to the applicant with an approval number which must be included in the remarks section (18) of the flight plan.
There are restrictions on entry and operation within the TRAs on General Aviation operations.
For information on the applicable restrictions within each individual TRA click on the link below to a chart depicting the TRA and a Flight Restriction Notice which outlines the flight restrictions pertaining to each.
For flights which wish to enter or operate within the TRAs and cannot comply with the flight restrictions, a formal request shall be made by email at least 48 hours in advance of departure to the controlling officer of the Department of Justice and Equality, by email to co-flights2011@justice.ie. to include in the subject line the text "TRA Applications" (not case sensitive). If you do not include the text "TRA Applications" within the subject line-your request may be rejected. You will receive an automatic reply to your email application -THIS IS NOT AN APPROVAL. The appropriate approval if granted will be relayed to the applicant with an approval number which must be included in the remarks section (18) of the flight plan.
Any queries with regards to the conduct of flight may be addressed to the Flight Operations Department, Irish Aviation Authority (email fod@iaa.ie) or telephone +35316031117 / 1148 / 1410 between the hours of 0900hrs and 1700hrs local Monday to Friday.
Military Airspace will be active for the duration of the visit and restrictions will apply. The military authorities will issue NOTAMs with regards to conditions & restrictions which apply in military airspace.
Warning
All aircraft flying within the TRAs in contravention of the flight restrictions may be subject to interception or interdiction by the Irish Defence Forces.
Pearse1983
Post by Pearse1983 » Fri May 13, 2011 10:01 pm
Warning
Meaning "We have a Cessna and we're not afraid to use it!!" :D
Pilot
Post by Pilot » Fri May 13, 2011 11:05 pm
Am I reading the restrictions correctly? As I read it, all GA (except aerial work) operations in and out of Weston between 17 and 20 May require pre-approval from the Dept of Justice?
trimflyingclub
Post by trimflyingclub » Fri May 13, 2011 11:44 pm
Pilot wrote:Am I reading the restrictions correctly? As I read it, all GA (except aerial work) operations in and out of Weston between 17 and 20 May require pre-approval from the Dept of Justice?
5.2 General aviation operations* shall not be permitted to operate within 15NM of the area centre unless specifically authorised by the controlling officer of the Department of Justice and Equality and in receipt of an Air Traffic Service.
BAL to Weston WST as we know is 3.5nm.
spider2000
Post by spider2000 » Sat May 14, 2011 12:18 am
Pearse1983 wrote:
Warning
No, this will mean PC-9M aircraft armed with .5" Heavy Machine Guns and HUD weapons aiming systems.
RV BLUE
Post by RV BLUE » Sat May 14, 2011 12:49 am
In the States its only flyable if you file a flight plan. I suggest its the same there....seems a bit silly to have to have pre approval from the Justice Department. I guess they mean the police (garda)
vanman
Post by vanman » Sat May 14, 2011 11:22 am
They have been practising radar guided interceptions with the PC9s, so anyone ignoring the TRAs will find themselves getting a chance for close up view of one. Then an unscheduled landing at a destination not of their choice. Followed by a chat with some unsmiling members of the Garda Siochana.
shrtfld
Post by shrtfld » Sun May 15, 2011 6:49 pm
Given how bad the weather has been for VFR flying since the start of May and looking at Met.ie for the next 3 or 4 days, I don't see too many of us being affected by the TFR's - for this week at least.
Then knowing our luck the weather will go CAVOK and light winds from Thursday for a week!!!
Shrtfld
Bearcat
Post by Bearcat » Tue May 17, 2011 7:57 pm
jayzuz, I'd have loved to give the cub a spin but alas.....
StrikeCommand
Post by StrikeCommand » Tue May 17, 2011 10:27 pm
An Air Corps 172 was busy patrolling Ashford-Rathnew-Wicklow area today for a good 3 hours around lunchtime - was that part of the security circus I wonder?
michael747
Post by michael747 » Wed May 18, 2011 9:18 am
I'd say the queen was impressed, A single 172... no wonder everything was ok
M747
:D
hedgehopper
Post by hedgehopper » Wed May 18, 2011 10:22 am
possibly the same air corps 172 headed in the direction of limetree and then buzzed clonbullogue airfield for 30 mins yesterday evening , there keeping an eye on the busy airfields !
Users browsing this forum: No registered users and 8 guests
